Weisst doch wies ist
Oki meine LogCat:
08-22 15:57:01.433: D/AndroidRuntime(2179): CheckJNI is ON
08-22 15:57:01.515: D/dalvikvm(2179): Trying to load lib libjavacore.so 0x0
08-22 15:57:01.535: D/dalvikvm(2179): Added shared lib libjavacore.so 0x0
08-22 15:57:01.593: D/dalvikvm(2179): Trying to load lib libnativehelper.so 0x0
08-22 15:57:01.593: D/dalvikvm(2179): Added shared lib libnativehelper.so 0x0
08-22 15:57:01.736: E/cutils-trace(2179): Error opening trace file: No such file or directory (2)
08-22 15:57:02.785: D/AndroidRuntime(2179): Calling main entry com.android.commands.pm.Pm
08-22 15:57:02.895: W/ActivityManager(285): No content provider found for permission revoke: file:///data/local/tmp/KidsGesundheitssurvey.apk
08-22 15:57:03.025: W/ActivityManager(285): No content provider found for permission revoke: file:///data/local/tmp/KidsGesundheitssurvey.apk
08-22 15:57:03.025: I/PackageManager(285): Copying native libraries to /data/app-lib/vmdl-1963368662
08-22 15:57:03.423: D/dalvikvm(285): GC_FOR_ALLOC freed 576K, 33% free 6222K/9228K, paused 153ms, total 153ms
08-22 15:57:04.223: D/dalvikvm(285): GC_FOR_ALLOC freed 885K, 33% free 6264K/9228K, paused 156ms, total 156ms
08-22 15:57:04.793: D/dalvikvm(285): GC_FOR_ALLOC freed 927K, 32% free 6278K/9228K, paused 149ms, total 150ms
08-22 15:57:05.443: D/dalvikvm(285): GC_FOR_ALLOC freed 943K, 32% free 6282K/9228K, paused 150ms, total 150ms
08-22 15:57:05.863: I/ActivityManager(285): Force stopping package com.example.kidsgesundheitssurvey appid=10050 user=-1
08-22 15:57:05.863: I/ActivityManager(285): Killing proc 2135:com.example.kidsgesundheitssurvey/u0a10050: force stop com.example.kidsgesundheitssurvey
08-22 15:57:05.873: W/ActivityManager(285): Force removing ActivityRecord{41a32c18 u0 com.example.kidsgesundheitssurvey/.MainActivity}: app died, no saved state
08-22 15:57:05.985: W/InputDispatcher(285): channel '41a6e370 com.example.kidsgesundheitssurvey/com.example.kidsgesundheitssurvey.MainActivity (server)' ~ Consumer closed input channel or an error occurred. events=0x9
08-22 15:57:05.985: E/InputDispatcher(285): channel '41a6e370 com.example.kidsgesundheitssurvey/com.example.kidsgesundheitssurvey.MainActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
08-22 15:57:06.024: I/WindowState(285): WIN DEATH: Window{41a6e370 u0 com.example.kidsgesundheitssurvey/com.example.kidsgesundheitssurvey.MainActivity}
08-22 15:57:06.024: W/InputDispatcher(285): Attempted to unregister already unregistered input channel '41a6e370 com.example.kidsgesundheitssurvey/com.example.kidsgesundheitssurvey.MainActivity (server)'
08-22 15:57:06.403: I/Choreographer(413): Skipped 35 frames! The application may be doing too much work on its main thread.
08-22 15:57:06.534: W/InputMethodManagerService(285): Got RemoteException sending setActive(false) notification to pid 2135 uid 10050
08-22 15:57:06.603: I/PackageManager(285): Package com.example.kidsgesundheitssurvey codePath changed from /data/app/com.example.kidsgesundheitssurvey-2.apk to /data/app/com.example.kidsgesundheitssurvey-1.apk; Retaining data and using new
08-22 15:57:07.033: I/PackageManager(285): Running dexopt on: com.example.kidsgesundheitssurvey
08-22 15:57:08.683: W/dalvikvm(2190): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawDividersHorizontal incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
08-22 15:57:08.683: W/dalvikvm(2190): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawDividersVertical incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
08-22 15:57:08.693: W/dalvikvm(2190): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawHorizontalDivider incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
08-22 15:57:08.693: W/dalvikvm(2190): method Lcom/actionbarsherlock/internal/widget/IcsLinearLayout;.drawVerticalDivider incorrectly overrides package-private method with same name in Landroid/widget/LinearLayout;
08-22 15:57:10.293: D/dalvikvm(2190): DexOpt: load 648ms, verify+opt 1525ms, 1273684 bytes
08-22 15:57:10.413: W/PackageManager(285): Code path for pkg : com.example.kidsgesundheitssurvey changing from /data/app/com.example.kidsgesundheitssurvey-2.apk to /data/app/com.example.kidsgesundheitssurvey-1.apk
08-22 15:57:10.413: W/PackageManager(285): Resource path for pkg : com.example.kidsgesundheitssurvey changing from /data/app/com.example.kidsgesundheitssurvey-2.apk to /data/app/com.example.kidsgesundheitssurvey-1.apk
08-22 15:57:10.446: I/ActivityManager(285): Force stopping package com.example.kidsgesundheitssurvey appid=10050 user=-1
08-22 15:57:10.623: D/dalvikvm(285): GC_FOR_ALLOC freed 917K, 32% free 6313K/9228K, paused 148ms, total 148ms
08-22 15:57:10.933: I/ActivityManager(285): Force stopping package com.example.kidsgesundheitssurvey appid=10050 user=0
08-22 15:57:11.063: D/dalvikvm(413): GC_EXPLICIT freed 639K, 19% free 7230K/8916K, paused 5ms+14ms, total 117ms
08-22 15:57:11.193: D/dalvikvm(1877): GC_EXPLICIT freed 154K, 13% free 2837K/3248K, paused 5ms+8ms, total 98ms
08-22 15:57:11.373: I/InputReader(285): Reconfiguring input devices. changes=0x00000010
08-22 15:57:11.453: D/BackupManagerService(285): Received broadcast Intent { act=android.intent.action.PACKAGE_REMOVED dat=package:com.example.kidsgesundheitssurvey flg=0x8000010 (has extras) }
08-22 15:57:11.503: W/ContextImpl(1894): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1385 android.content.ContextWrapper.startService:473 android.content.ContextWrapper.startService:473 com.android.keychain.KeyChainBroadcastReceiver.onReceive:12 android.app.ActivityThread.handleReceiver:2424
08-22 15:57:11.753: I/InputReader(285): Reconfiguring input devices. changes=0x00000010
08-22 15:57:11.843: D/BackupManagerService(285): Received broadcast Intent { act=android.intent.action.PACKAGE_ADDED dat=package:com.example.kidsgesundheitssurvey flg=0x8000010 (has extras) }
08-22 15:57:11.873: V/BackupManagerService(285): removePackageParticipantsLocked: uid=10050 #1
08-22 15:57:11.933: V/BackupManagerService(285): addPackageParticipantsLocked: #1
08-22 15:57:12.023: D/dalvikvm(371): GC_FOR_ALLOC freed 297K, 12% free 2714K/3052K, paused 321ms, total 342ms
08-22 15:57:13.293: W/GCoreUlr(595): sending intent to update reporting state
08-22 15:57:13.894: I/GCoreUlr(595): Ensuring that reporting is stopped because of reasons: (no Google accounts)
08-22 15:57:13.903: D/GCoreFlp(595): Unknown pending intent to remove.
08-22 15:57:13.923: I/GCoreUlr(595): Ensuring that reporting is stopped because of reasons: (no Google accounts)
08-22 15:57:13.923: D/GCoreFlp(595): Unknown pending intent to remove.
08-22 15:57:13.933: I/GCoreUlr(595): Unbound from all location providers
08-22 15:57:14.723: D/dalvikvm(285): GC_EXPLICIT freed 1093K, 36% free 5942K/9228K, paused 370ms+52ms, total 1963ms
08-22 15:57:15.073: D/AndroidRuntime(2179): Shutting down VM
08-22 15:57:15.082: D/jdwp(2179): Got wake-up signal, bailing out of select
08-22 15:57:15.082: D/dalvikvm(2179): Debugger has detached; object registry had 1 entries
08-22 15:57:15.702: W/RecognitionManagerService(285): no available voice recognition services found for user 0
08-22 15:57:16.502: D/AndroidRuntime(2202): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
08-22 15:57:16.502: D/AndroidRuntime(2202): CheckJNI is ON
08-22 15:57:16.572: D/dalvikvm(2202): Trying to load lib libjavacore.so 0x0
08-22 15:57:16.602: D/dalvikvm(2202): Added shared lib libjavacore.so 0x0
08-22 15:57:16.672: D/dalvikvm(2202): Trying to load lib libnativehelper.so 0x0
08-22 15:57:16.672: D/dalvikvm(2202): Added shared lib libnativehelper.so 0x0
08-22 15:57:16.805: E/cutils-trace(2202): Error opening trace file: No such file or directory (2)
08-22 15:57:17.843: D/AndroidRuntime(2202): Calling main entry com.android.commands.am.Am
08-22 15:57:17.863: D/dalvikvm(2202): Note: class Landroid/app/ActivityManagerNative; has 163 unimplemented (abstract) methods
08-22 15:57:17.902: I/ActivityManager(285): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.example.kidsgesundheitssurvey/.MainActivity} from pid 2202
08-22 15:57:17.962: W/WindowManager(285): Screenshot failure taking screenshot for (328x583) to layer 21005
08-22 15:57:18.024: W/dalvikvm(2213): PR_CAPBSET_DROP 0 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.024: W/dalvikvm(2213): PR_CAPBSET_DROP 1 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.024: D/AndroidRuntime(2202): Shutting down VM
08-22 15:57:18.036: W/dalvikvm(2213): PR_CAPBSET_DROP 2 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.036: W/dalvikvm(2213): PR_CAPBSET_DROP 3 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 4 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 5 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 6 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 7 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 8 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.042: W/dalvikvm(2213): PR_CAPBSET_DROP 9 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.055: D/dalvikvm(2202): Debugger has detached; object registry had 1 entries
08-22 15:57:18.062: W/dalvikvm(2213): PR_CAPBSET_DROP 10 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.062: W/dalvikvm(2213): PR_CAPBSET_DROP 11 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.062: W/dalvikvm(2213): PR_CAPBSET_DROP 12 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.062: W/dalvikvm(2213): PR_CAPBSET_DROP 13 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.062: W/dalvikvm(2213): PR_CAPBSET_DROP 14 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 15 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 16 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 17 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 18 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 19 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 20 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 21 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 22 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 23 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 24 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 25 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 26 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 27 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 28 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 29 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 30 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 31 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 32 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: W/dalvikvm(2213): PR_CAPBSET_DROP 33 failed: Invalid argument. Please make sure your kernel is compiled with file capabilities support enabled.
08-22 15:57:18.083: D/dalvikvm(2213): Not late-enabling CheckJNI (already on)
08-22 15:57:18.102: I/ActivityManager(285): Start proc com.example.kidsgesundheitssurvey for activity com.example.kidsgesundheitssurvey/.MainActivity: pid=2213 uid=10050 gids={50050, 1028}
08-22 15:57:19.142: I/Choreographer(285): Skipped 40 frames! The application may be doing too much work on its main thread.
08-22 15:57:21.543: D/dalvikvm(2213): GC_FOR_ALLOC freed 126K, 6% free 2793K/2968K, paused 47ms, total 50ms
08-22 15:57:21.563: I/dalvikvm-heap(2213): Grow heap (frag case) to 3.844MB for 1127536-byte allocation
08-22 15:57:21.693: D/dalvikvm(2213): GC_FOR_ALLOC freed 2K, 5% free 3892K/4072K, paused 123ms, total 123ms
08-22 15:57:22.543: I/Choreographer(2213): Skipped 69 frames! The application may be doing too much work on its main thread.
08-22 15:57:22.643: D/gralloc_goldfish(2213): Emulator without GPU emulation detected.
08-22 15:57:22.803: I/ActivityManager(285): Displayed com.example.kidsgesundheitssurvey/.MainActivity: +4s802ms
