Samsung Galaxy S Plus (GT-I9001) - [KERNEL][3.4.106][LP][ION] K^Kernel 3.4.106 v4.5 for LP 5.0 [04/04/2015] für CM 12
  • Antworten:3
T. P.
  • Forum-Beiträge: 66
08.03.2015, 05:25:42 via Website
(danger) Gilt nur in Verbindung mit Samsung Galaxy S Plus (GT-I9001 + CyanogenMod 12.0 by ADC-Team) (danger)
(danger)Ich selber stellen keine Downloads bereit / Nur den Link zu den Original Post & Original Downloadseiten des Betreffenden Download(danger)
Auch Haftet Christopher83 und Ich nicht für Etwaiger Fehler oder Brick´s des Gerätes
•v4.5 - für ADC CM 12.0 und anderen Roms basierend auf CM 12.0 ADC-Team
Kernel Hauptfeatures:
- Kernel 3.4.x
- Kernel based on more updated kk_2.7-stable branch of CAF (Code Aurora Forum)
- Sources synched with cm-12.0 repo branch of DevCon Team
- Built with my custom Linaro 4.9.3-2015.03 toolchain optimized for Cortex-A8
- Built with Cortex-A8 and NEON VFP optimization flags (both kernel and modules)
- Built with -O3 optimization flag (both kernel and modules)
- CPU overclockable up to 1824 MHz
- CPU frequencies undervolted (UV version) or extremely undervolted (EXUV version)
- CPU voltage control VDD sys interface (click for more details)
- Dynamic memory allocation of ION heaps through CMA (Contiguous Memory Allocator)
- Dynamic memory allocation of PMEM ADSP heap through CMA (Contiguous Memory Allocator)
- Approximately 426MB of free RAM
- Init.d support
- Fast Charge support (default disabled, click for more details)
- Battery Life eXtender support (default disabled, click for more details)
- Ram Console support (click for more details)
- Backlight Notification v10 (BLNv10) (click for more details)
- USB OTG support (if also implemented on rom side)
- Customizable vibration intensity (click for more details)
- Lowered display panel voltage
- Lowered touchscreen voltage
- Lowered wifi voltage
- Lowered swappiness (60 -> 45)
- Increased CPU frequency during boot
- Optimized AES and SHA1 routines for ARM cpu architecture
- Fixed 100% battery notification after charger unplug
- Increased audio volume on board side
- Con Kolivas' CK3 Tweaks
- Optimized SLUB memory allocator
- Optimized ARM RWSEM (read/write semaphore) algorithm
- Optimized asynchronous I/O latency on solid state disks
- Disabled Gentle Fair Sleepers for better UI performance
- CIFS support on boot
- Memory compaction
- Dynamic compression of clean pagecache pages
- New display drivers from Samsung Galaxy SII
- Updated light sensor driver and display driver light sensor changes
- Updated sensor drivers
- Phantom key presses filter (click for more details)
- Dynamic FSync v1.2 (click for more details)
- Dynamic dirty page writebacks (click for more details)
- VM tweaks for performance and less battery consumption
- Customizable timeout for touchkeys backlight after a key press or touchscreen press (click for more details)
- Customizable activation status of touchkeys backlight on touchscreen press (click for more details)
- Timer slack controller (click for more details)
- Dynamic management of the minimal timer slack value during suspend/resume (click for more details)
- LowMemoryKiller management of not killable processes (click for more details)
- F2FS and exFAT support
- Additional TCP Congestion algorithms
- Updated ZRam, ZSMalloc, ZCache built-in modules
Auswählbare CPU Governor:
- Adaptive
- BrazilianWax
- Conservative
- Hyper
- Intellidemand
- Interactive
- InteractiveX
- LionHeart
- LulzActive
- OnDemand (default)
- OnDemandX
- Performance
- Powersave
- SmartAssV2
Auswählbare I/O Schedulers:
- BFQ
- CFQ
- Deadline
- Fiops
- Noop
- ROW (default)
- SIO
- V(R)
Bekannte Probleme:
nichts bekannt
Wie Installiert man den Kernel:
1) Download die Kernel.zip File auf den internen Speicher oder die Externe SD-Karte
2) Rebootet ins TWRP Recovery 2.8.1.0
3) Flash die Kernel .zip File
4) Rebootet ins System
k^Kernel Downloads für LP ION+PMEM ADSP:
K^Kernel LP-5.0 v4.5 Mediafire Folder
https://www.mediafire.com/?y07ya5fmc7xot
Note: You must use the TWRP recovery with new partition assignments you may find inside ADC CM 12.0 thread
[FAQ] Governors & Schedulers
http://android-hilfe.de/kernel-fuer-samsung-galaxy-s2/180437-faq-governors-schedulers.html#post2419544
Original Thread (Englisch):
K^Kernel von Christopher83
HIER GEHT ES IN DEN ORIGINAL THREAD (Englisch): http://forum.xda-developers.com/galaxy-s-i9000/i9001-development/kernel-kkernel-3-4-105-v1-0-lp-5-0-t2989356
Contributors
Christopher83
Source Code: https://github.com/Christopher83/sam...0/tree/cm-12.0
Kernel Special Features: Customized kernel 3.4.x for LP 5.0 rom (CM 12.0 and derivatives) with ION memory allocations
Version Information
*Status:* Stable
Current Stable Version: v4.5
Stable Release Date: 2015-04-04
Created 2014-12-31
Last Updated 2015-04-04
— geändert am 04.04.2015, 21:28:19
T. P.
08.03.2015, 05:35:09 via Website
reserv
T. P.
08.03.2015, 05:35:27 via Website
reserv
T. P.
08.03.2015, 05:35:34 via Website
reserv
