1Version 4.4:
2---- NEEDS A FULL CLEAN INSTALLATION ----
31- Added support for various devices (officially support over 25 devices now !)
4-m7ul, m7tmo, m7att, m7spr, jfltecan, jfltetmo, jfltespr, jflteusc, jfltevzw, jflteatt, and more !!
52- Added BAMF Theme Engine
63- Memory Leak Fixes (in frameworks_base and in frameworks_native)
74- Various updates and fixes for HTC One users
85- Addition of HALO multi-window notification system (By PA)
96- ReVoltControl has been added :
10- ReVolt Control is an application based on ROMControl (By AOKP) which features various features specially for ReVolt ROM
117- Added Welcome app to help users know the ROM
128- Added option to share with people you use ReVolt ROM (In Settings => About Phone)
139- ReVoltLauncher has been added with various features
1410- Replace CircleMOD with CM's Circle Battery with more functions
1511- Added Rush Battery (Thanks to Rootbox)
1612- Update Roboto Font (From Android 4.3)
1713- LTE Toggle Fixes
1814- Add Network Speed Indicator (Thanks to Team ThinkingBridge)
1915- Added TeamBACKED's Toggle colouring system (Thanks to them and daxxmax)
2016- Added HALO Colourizing engine (Thanks to daxxmax)
2117- Halo could save it's place and can be disabled
2218- MultiUser Selector has been cleaned up
2319- Add 2G/3G option to Profile Connections
2420- Added Music Toggle
2521- Option to launch apps from Recents in Floating mode
2622- Privacy Guard has been added
2723- More Pie Options and optimizations
2824- Various fixes and deadlock fixes
2925- Fix Lockscreen FC/Reboot
3026- Option to pause Underlaying app in Halo
3127- Fix BatteryBar showing in all 3 places at same time
3228- More Battery Friendly
3329- New Auto-Brightness Controlling system
3430- Lockscreen see Through
3531- Low Battery Sound Policy Controller
3632- Show date on 2 lines in Notification Center
3733- Pie : Angle Chooser
3834- Smoother and Faster Notification pull down
3935- AOKP Ribbons updated
4036- Fix Tablet UI Battery showing 0%
4137- WirelessADB Toggle
4238- AOKP Ribbons Toggles
4339- Fix IME Switcher staying on top
4440- Fix StayAwake Toggle
4541- Don't Enable WiFi when AirPlane Mode is on
4642- Added Hybrid Toggle
4743- Added ReVolt Statistics
4844- Added Hardware Key Remapping
4945- Add CMFileManager (Except for AROMA Devices)
5046- Add Apollo Music Player (Except for AROMA Devices)
5147- ReVoltLauncher support Per-App-Color
5248- MMS Updates
5349- More Features added to Camera (Except for Nexus Devices_
5450- Update Dark ReVolt for EMail app and add it for Calculator
5551- HTC One users have a powerful kernel
5652- Use PA's Custom Kernel for Nexus 4 Users
5753- Fix Grouper Build and Fix n7000 and n7100 builds
5854- Added optimizations for mako users
5955- Specific Fixes and features for devices
6056- Gesture Lockscreen Added
6157- Add Custom Lockscreen BackGround option
6263Version 4.3:
641-Merges Latest AOKP and CM changes
652-Added AOKP Ribbons
663-Added StayAwake Toggle
674-Fix hot reboots
685-Fix Navigation Bar layout on Phablet UI
696-Fix Per-App-Color System (Thanks to Bajee11)
707-Fix SOD on lockscreen while on lockscreen (PAC Rom)
718-Add Permissions Manager
729-DARK ReVolt is extended to Calendar, Keyboard and E-Mail
7310-Hidden StatusBar Pulldown Feature
7411-Fix Pie Toggle (Thanks to Bajee11)
7512-General fixes and memory leak fixes
7613-Added feature from CM Camera
7714-Add initial Support for Oppo Find5, Samsung Galaxy S4(jfltetmo and jfltecan) & HTC one
7815-Fixed SystemUI crashes
7916-Fixed FC on Tablet UI mode in Lockscreen (Thanks to DaxMaxx)
8017-Modular BackUP tool added
8118-Added build info in flashing
8283Version 4.2:
841-Has latest merges from AOKP Sources
852-Add Power Widget
863-Add Notification Widgets
874-Fix Lockscreen Delay issues
885-Fix Pie issues
896-Dark ReVolt is much better now
907-Fix ROM Control weird problems
918-Remove Xposed Modules
929-GooManager is now properly supported
9310-Returned the MultiUser Feature
9411-Feature so Wallpaper won't be reset if SystemUI is restarted
9512-A lot of fixes
9613-Revamp Customizations in Settings
9798Version 4.1:
991-Based on Latest AOKP Source with latest Merges
1002-Fixed the ASCII Graphic size while installing
1013-Add Custom Toggle
1024-Add Reboot Toggle
1035-Add Screenshot Toggle
1046-More options in Lockscreen in ROM Control
1057-Add Paranoid Preferences with Hybrid Engine and support for Phone UI, Tablet UI, Phablet UI & PA Colors (Still beta and buggy)
1068-Dark ReVolt starts to take action
1079-Add option to daydream while on wireless charger (Only Nexus 4)
10810-Add option to disable Camera sounds
10911-Removed the duplicate CM Profils in Settings
11012-Power Widget
11113-Add Status Bar Hide Toggle
11214-Add option to disable 270 degree rotation
11315-Added Scrollable Toggles
11416-Completely Revamped Lockscreen Section in ROM Control
11517-Add A LOT of options in Mms
11618-Added CM's Calculator for more functionality
11719-Bug Fixes
11820-More Translations added
119120Version 3.3:
1211-Based on Latest AOKP Sources (With Build 3 Merges too)
1222-Fixed Battery Issues with all devices
1233-Removed duplicate Cameras faced on some devices
1244-Updates and fixes for PIE UI
1255-Fixes for FCs
1266-Added option to enable or disable Electron Beam (CRT On and Off Effect)
1277-Added DPI Changer
1288-Update Xposed App
129Nexus 4 :
1301-Added HalfBreed Tweak in kernel (thanks to Moles)
1312-Added TouchControl Support
132133Version 3.2:
1341-Based on Latest AOKP Sources
1352-Fixes for Signal Issues
1363-Lock Screen Targets added (ReVolt Control)
1374-Pie UI added (ReVolt Control) (Thanks to Paranoid Android Team)
1385-Updated Solid Explorer
1396-ReVolt Control is completely polished with new UI and new Icons (Thanks to Kroz's Hue Theme)
1407-Updated Xposed Intaller and Xposed DPI
1418-Re added Multi User which was by mistake missing from some builds
1429-Fixed Performance Control FC from Settings App
14310-Fixes for WiFi weird actions
144Nexus 4 Specific :
1451- Support for Stable Builds (No AROMA Installer for now, but GApps and launchers are going to be included)
1462- Some fixes so Pie won't FC
147Samsung Galaxy S2 I9100 :
1481- A LOT Of work so the battery would work MUCH MUCH Better
1492-Updated DorimanX Kernel to 7.46
150Samsung Galaxy S3 I9300 :
1511- Fix Siyah Kernel Problems and Lag issue by adding a newer one
1522- Re added Missing MultiUser from 3.1.0
