- Forum-Beiträge: 11.646
20.10.2012, 23:19:53 via App
20.10.2012 23:19:53 via App
Flash Rom in CWM or TWRP
Wipe data/factory reset if you are coming from another ROM
Flash the zip
Wipe cache/dalvik cache
Then flash GApps.
Reboot
Download Official Milestone 1
http://goo.im/devs/aokp/p3110/aokp_p3110_jb_milestone-1.zip
GApps: http://goo.im/gapps
What works:
Samsung Keyboard Dock
Almost Everything
What doesn't work:
IR Blaster?? A WIP
You tell me...
Kernels
The same custom kernel used in AOKP ROMs now available to use in all AOSP based ROMs. (AOKP, CM10, ParanoidAndroid) Will not work with stock Touchwiz based ROMs!!
These use the anykernel flash method so it creates a new boot.img on the fly. It will not interfere with any customizations that may be in your current boot.img's ramdisk.
Download Kernel
http://androtransfer.com/?developer=...folder=Kernels
AOKP's Source can be found here: Github
Thanks to:
AOKP Team
codeworkx and Teamhacksung for the initial CM10 work
Please do not copy and paste this post anywhere else. Always point the post to this thread since it will always have the most recently updated version. Thank you and enjoy the Jelly Bean infused Unicorns!
AOKP Samsung p31xx and p51xx Device Maintainer
homepage - AOKP Home
twitter - @cwmenard
github - cmenard
rennt wie sau das teil
— geändert am 30.10.2012, 15:56:31
